  • Replies 86
FOr future references, i took my line to Barett Brothers in Fyshwick. They have been very helfull so far and have a 3-4 week quote as it will take 1.5-2 weeks just for delivery of parts. (My whole rear end is being shipped over hehe.
But yea they give me updates and that. Their place seemed heaps clean and professional
How are you going with all phil? Jerrys starting my car today apparently, wasnt happy though as it was left outside in the HEAVY AS F**K rain the other day so at least its washed down but an open engine bay with exposed harnesses and other things, theres rust on my camber adjustment points on my coilovers now... ill be after some compo or at least fixing of that...
I really feel sorry for you mate, GunMetalR33 was refering to me in his posts.... I have a candy red datsun ute that was tboned (not huge damage, and no chassis straightening required)....... it took 10 months for him to fix it.
For the first 2-3 months, every time I called and went past - "ah maite, you see, I had to order the genuine parts from OS, and it takes 2 weeks for them to get here" Every time same story whether I dropped past or called.
He then f**ked around getting the work started - "ah maaaiiitte, you see, all my workers, they quit today" (little wonder, your a bloody wanker).
So apparantely all of his workers quit, but never actually left because they were all there for the next 6 months (probably because he is such a great manager and pays them really well)
Then finally when I get the car back.... "ah maiiiitee.... the blinkers were broken right".... aahhh how does no grab you - i took the car anyway cause I wanted it the hell away from him and that poxy workshop.
And the paint job was crap - it is orange peeled in places.
f**k them - the place is called XXXXXXXXXXX - do not go there!!!!
Sorry if anyone is friends with this bloke but he stuffed me around big time and I would never ever recommend anyone goes there - and I made sure I told the insurance company everything that went on.
Anyway. enough anger venting :pirate: - Good luck getting your car outta there (and if you cant, get back in there asap and make sure that you have turned the boost down or dropped the rev limiter)
Anyway. enough anger venting :laugh: - Good luck getting your car outta there (and if you cant, get back in there asap and make sure that you have turned the boost down or dropped the rev limiter)
OH SH#T!!!
I'm going there today at 3... I will advise on the goings on after my talk... I'm in bug trouble i think and might have to sell car as a wreck.... :)
OH SH#T!!!
I'm going there today at 3... I will advise on the goings on after my talk... I'm in bug trouble i think and might have to sell car as a wreck.... :laugh:
thats terrible man! :rant:
get angry and break 14k of stuff and whatever your cars worth and never come back :)
Ok, Here is the go,
I went in and spoke with the workshop. I have given an official letter of demand of services paid for and given him till the end of November, also explained in the letter is the fact that 2 weeks is plenty of time after what will be a total of 7 months in the shop since Full payment has been made....
So. I then went to see the person putting in the engine and he will have it back to him by wed and that will allow plenty of time. The mechanic was also quite suprised and commented on the amount of patience i have shown in this. Also in the latter it states that NRMA and the MTRA (motor vehicle repairers assoc.) who is going to insure the car will inspect it before delivery to ensure that the work is up to standard and of a quality that a certified MTRA workshop should perform.
The workshop then responded with an open yes. It will be completed and i know you need your car and again also blaming parts, and the mechanic with the engine taking his time...
I will advise the goings on on tuesday when i again visit the workshop...
Cheers....
Im amazed at that...
he couldnt get rid of my car quick enough ay.
Good luck with it man, glad youve got big gun backup to help out :P
Its sort of hard due to him haing all the money. So this was the best was to officially sort it out and get it going...
It will be so nice to have the GTR on the road again...
tell me about it ay.
im hoping to have mine registered in the next 3 weeks :)
so much running around to do in the meantime though
- air con regassed
- front tyres changed
- change exhaust and coilovers back to stock
- rego inspection...
itll be a very rushed job :)
- air con regassed
You Love it though....
I cant wait to do that stuff again... :)
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
