The AR-X is the sporty off-road model, similar to the Subara Outback, and the 25T or whatever is the standard model. the AR-X has higher suspension and the flared guard things. not a fan of that model, but the 3.5L V6 6spd model is looking mighty fine in a few years time.
https://www.sau.com.au/forums/topic/141451-stagea-ar-x/#findComment-2635867
Ok that's why it looks like a subibus, cause it's the offroad one. Yeah I've checkout out the V6 one online and they're nice. My mates got the v35 with twinturbos and that engine is very tough, can wait to see it at wakefield on Wed. :(
https://www.sau.com.au/forums/topic/141451-stagea-ar-x/#findComment-2636569
I 've seen these in the flesh and yes the plastic guards dont do much for it - very XC volvoish.
The rear door has a two way opening system - another Stagea innovation. Not that this was the first time this idea was invented, just that it looks like someone actually thought about it before slapping the car together.
The picture doesnt give the dash the credit that is due, it is very creamy...very yum.
That flap on the top of the centre console opens up and the tv/dvd screen pops up.
The price has come down significantly since it was last advertised for around $50k
https://www.sau.com.au/forums/topic/141451-stagea-ar-x/#findComment-2636962
There you go, do you know about the tiptronic? Would be nice to retrofit to a series 2 if it's 6 speed.
The TV's screen is similar to the v35 then.
Edited by Stage Flight
https://www.sau.com.au/forums/topic/141451-stagea-ar-x/#findComment-2636987
Just wondering, are the 35-series Stageas ready for compliancing & registering in Australia now? This SEVS thingie is just making me very confused.
Or is that Stagea AR-X a personal import?
https://www.sau.com.au/forums/topic/141451-stagea-ar-x/#findComment-2640177
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
