Hey all I just have a couple of Q's I need answered...
Someone I know is looking to buy a RB25DET Neo from an import place which includes engine, turbo, loom etc for $4900 it supposedly has 40,000km's on it but I have told him he had better do a leak down/compression test on it before handing over any money... does this sound like an ok price for the package or should he be able to get a half cut for this much???
also will a standard R33 exhaust system from a GTS-T bolt up to the NEO turbo or are they different studs or something ??? (n00b question I know)
Cheers Leigh
https://www.sau.com.au/forums/topic/141662-information-about-rb25det-neo/
Sounds like an ok price, definately do the tests on it though (it may be hard to get it to operating temperature though).
As for the exhaust, I believe the Neo has a larger exhaust housing on it so I dont think the exhaust will fit.
While your on the topic...what is the difference between the NEO compared to the RB25DET?? I've actually been trying to find this out for the past few days.
EDIT: typo
Edited by R3sp3ct
The differences that I've heard of are:
- The crank angle sensor is different to an R33 one. An R33 one has a metal cover. The Neo one has a matt black plastic cover. If you need to see what it looks like try finding a picture of either a Neo or an R34 RB26DETT, they both have the same CAS cover.
- The plenum is a tad smaller than an R33 one and has a slightly squarer shape (for lack of a better description)- Apparently for better bottom end power
- The crossover pipe has a secondary throttle body which is about 2-3 inches before the main throttle body on the plenum, for the traction control.
- Neos have smaller top feed injectors, as opposed to R33 side feed injectors. 340cc vs 370cc or something.
- The R33 coil pack covers have that "NISSAN 2500 TWIN CAM 24 VALVE" badge on them on top of cylinder #2 roughly. The R34 ones have nothing on the coil cover at all due to the plastic engine cover and the intake gear almost completely obscuring the coil pack and cam covers.
- The vaccum hosing and coolant bleed points are in rather different spots on the Neo intake. (At the back of the inlet manifold)
- There is an igniter in each ignition coil as opposed to the other RB motors which has a single igniter at the back of the motor for all the coil packs
- The turbo has a nylon composite compressor wheel and what's supposed to be the same as a VG30 exhaust housing
- Solid lifters a la RB26 (mine certainly has a different sounding top end noise)
- RB26 conrods (either the same or similar)
- They don't have variable cam timing on the exhaust but the variation on the intake is meant to be different to the R33 one. The R33 one is supposed to be some kind of on/off arrangement and the R34 one is some kind of intermittent/available on demand kind of thing
- The ECU has a very different pinout
Anyways that's what comes to mind, I'm no expert so a lot of that might be incorrect
Oh, and the exhaust housing.... mine has an R33 dump pipe on it :yucky: The original dump pipe was on the motor when we got it and it looked exactly the same as an R33 one.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
