Hey There Roger!
For Accessories you can't go pass buying online from
www.nengun.com
or
www.greenline.jp (althou they are having some website issue at the moment)
You will find they are both very well priced and much cheaper than buying local
althou if you want to buy local you can check out
Jshop
Vision r ( http://www.visionr.com.au/ )
Spl1t Second
Wheelspin
X-Speed
Evo-R
also check out the Business Trader Section on the fourm ( http://www.skylinesaustralia.com/forums/in...p?showforum=141 )
For Service it depends where you live
you have
Hyperdrive
Speedworks
Cypher Industries
Top Racing
X-Speed
Just to name a few
My personal recommendation are EVO-R, Hypdriver, Cypher Industries.
If you need anymore help just ask :pirate:
Also welcome to SAUWA :( If you would like to become a SAUWA Member here is some information --> http://www.skylinesaustralia.com/forums/in...showtopic=45740
Cheers Michael
https://www.sau.com.au/forums/topic/141813-brainless/#findComment-2641847
just after i got my car a guy down the stree got 1 almost the same as mine except his is red none turbo and auto i think... he had it for about 3 weeks then somthing fall on the windscreen and smashed it... he hasnt had it fixed yet been sitting there for about 2 months... i felt sorry for him i almost cried :pirate:
https://www.sau.com.au/forums/topic/141813-brainless/#findComment-2641881
I always thought there were very little r33 gts around, almost all i've seen are gtst.... are gts allowed to be imported with the servs scheme?
Anyway.. nice ride.. welcome to the formus..hope to see you around sometimes. Cheers!
https://www.sau.com.au/forums/topic/141813-brainless/#findComment-2642195
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
