What year ?
EDIT:: ahh didnt it see it, you got it under there!!
Bit expensive for me, good luck with the sale
This is just a general question.. anyone know the answer, would really appreciate if you post it..
You see the yellow round(indicator) rear lights on R-34's.. are they all the same as GT-R, GT-T etc.. is there any without the yellow bit?
also does R-34's come in series 1's and 2's like R33's?
Edited by pretender-
https://www.sau.com.au/forums/topic/141924--/#findComment-2644399
Location ? ACT by the looks of it ....
What are the rear sets like - big/flat enough to fit a baby seat in ? Or not really big enough for anything in the back ?
the back is big enough to seat 2 ,10 year old kids, I've got 2 boys one is 8 , the other is 7 and they have got no problems as room goes.it all depends what you are after cheers.
https://www.sau.com.au/forums/topic/141924--/#findComment-2645975
where about are u located?
im in sydney....
are u interested in a swap plus cash ur way?
Hi THO, Mate thanks for your quote!! but I really want to sell it , the car just seats in the garage!! and needs a new owner, someone keen to drive it.....cheers Alex :)
Edited by aleko69
https://www.sau.com.au/forums/topic/141924--/#findComment-2663210
hey man thats a well put together line........ nice and tidy... how negotiable are you on the price......... would you consider 25k
Hey untaxd' Thank you for the complements . I bought this car just under two years ago ,costed me over $32k
plus all the extras well over $10k so far , I'll consider anything over 28k.That including these new rims , This car its worth a lot more than that mate !! :wub:
The rims & tyres are brand new cost me $2800 3 months ago . :woot:
https://www.sau.com.au/forums/topic/141924--/#findComment-2687120
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
