Hmm... Slr Vs Normal Digial Cameras....
just a quick pic from today... SLR digial cemeras rock..... (6mp canon SLR)
(my normal digial camera, a Pentax (8mp) (700AUD) , is nowhere this quality... )
oh, this pic was taken in a workshop, with no extra lighting, and was a quick 'snap'
Edited by Zebbie
https://www.sau.com.au/forums/topic/141937-hmm-slr-vs-normal-digial-cameras/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
