Rda Rotors Group Buy - 5th & 6th Batches
  • Replies 113
  • 1 month later...
Ok, I have started batch # 7 here:
http://www.skylinesaustralia.com/forums/in...howtopic=158914
Please direct all inquiries for the next group buy in that link or click the link #7 in my signature...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
