R Racing Sports Xenon Filled 4500K HID Look Bulbs
Xmas Specials Now On
Transaction Instructions:
If you wish to make payment via Credit Card or your PayPal account simply click the button_buy_now_blue.gif button that corresponds to your desired selection, please be aware a 3% surcharge is payable. For payments made via direct deposit/bank transfer, or for further transaction details please follow the link below:
http://www.skylinesaustralia.com/forums/in...showtopic=82168
Front On Photo of Headlights | Front On Photo of Parker Bulbs
Price:
*H1 (Wattage: 55W, Temp: 4500K) - $40
*H1 (Wattage: 100W, Temp: 4500K) - $40
*H3 (Wattage: 55W, Temp: 4500K) - $40
*H3C (Wattage: 55W, Temp: 4500K) - $40 Delivered (On Special)
*H4 (Wattage: 55/60W, Temp: 4500K) - $40
*HB3 (Wattage: 65W, Temp: 4500K) - $40
*MTK Xenon Filled Parker Bulbs (Wattage: 8W) - $25
Postage & Handing:
1 Set: $10.50
2 Sets: $12.50
3 Sets: $15.50
4 Sets: $17.50
Click Bulb Type for Photo
R Racing Sports Package Deals
*The following listings are correct, however it is know that in some models there are some deviations; these are italised. If you have any concerns please check your current setup before ordering.
Nissan Skyline R32 GTR (Projector Style) - High (H3), Low Beam (H1) + Xenon Parker: $99 Delivered Xmas Special
Nissan Skyline R32 GTS-t (Projector Style) - High (H3), Low Beam (H3C) + Xenon Parker: $99 Delivered Xmas Special
Nissan Skyline R33 GTS25(-t) Series 1 & GTR Series 1 & 2 - High (H1), Low Beam (H1) & Xenon Parker: $99 Delivered Xmas Special
Nissan Skyline R33 GTS25(-t) Series 2 - High (H1), Low Beam (H1), Fog Lamp (H3) + Xenon Parker: $132.75 Delivered Xmas Special
Nissan Stagea WC34 Series 1 - Combined High & Low Beam (H4) + Fog Light (H3C) + Xenon Parker: $99 Delivered Xmas Special
Nissan Pulsar N16 High (H1), Low Beam (H1) + Xenon Parker: $99 Delivered Xmas Special
Holden Commodore VN H4 High/Low Beam, H3 High Beam + Xenon Parker: $99 Delivered Xmas Special
*Any combination of 2 bulbs and parkers - $99 Delivered
*Any combination of 3 bulbs and parkers - $132.75 Delivered
Colour Temperature Spectrum
These are Xenon filled bulbs rather than Halogen, they are not HID bulbs. The biggest attraction of this range are it's availability in the HC3 bulbs, which is used by many Japanese vehicle manufactures however doesn't have much after market support.
Basically all the bulbs within the range I am selling will look the same, with a 4500k colour temperature; making a uniform looking light show :(
  • 3 weeks later...
The Xenon filled bulbs are able to produce a far more natural light then halogen units; closer to "white light". However most people purchase the bulbs not for the implications of the temperature of light rather for aesthetics.
To obtain a 6000k temperature you would require a full HID setup, and this setup would be quite blue.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
