i have a quesion , im making a flange to accomodate my new bov , so it can be boltd to stock positioning , i wanted to know , would aluminium say about 5 mm thick or maybe a bit bigger , be good enough and endure the engine bay heat etc..? and not bend
basically im gonna just make the flange , drill the 2 holes to bolt in on , and a big hole in the centre same size as stock / then it just bolts the the bov , - an adaptor came with the bov , so all i will have to do is get it welded.
any thoughts ,thanks?
https://www.sau.com.au/forums/topic/142289-flange/
wouldnt need 5mm alloy, and is your adapter actually alloy?
cos if its steel or stainless, it wont weld to the flange you make from alloy.
https://www.sau.com.au/forums/topic/142289-flange/#findComment-2649339
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
