Yeah all in all it was a respectable cruise.
I was bloody tired after the hill street meetup afterwards thou...Your car did rather well out there slowpoke felt sorry for that RX7 that seemed to have blown something after his heat with that WRX. how much boost was u running slowpoke?
0.8 bar.. so probably bout 10-11 psi? ;) my cars stock just wit standard mods, exhaust and pod filter.. don even have a front mount :cheers:
Hiya Adam {Woodys} and Sei chai Slowpoke :laughing-smiley-014:, so u all like the hill street. It will be one more coming soon will let u all know when, so u guys get ready for it. Sei chai slowpoke dont forget me and u ar at the hill street hehehehe... :sorcerer:
Edited by Hoshima
I always see you in the Northbridge and Perth Slowy! I drive white R32 with mis-matched black rims, stickers and 3.75 straight pipe :P Soon to fit my BN kit. I have waved a few times but think you been with the fairys :P
:P cause im always at northbridge :P spotted a wingless white 33 opposite pot black bout 1am
uh..... let me guess... the guy wit the 32? that i sat in? which i took photo of? *doesnt want to mention name* :P
Lol.. theres nothin wrong with the RX7 Adam, she doing fine now. Adam pm me ur mobile number ?
haha i just realised who u r, u have that bloody hot 32GTR :)
im the guy with the gtst J TUNED lol. how r ya mate :woot: ?
haha i just realised who u r, u have that bloody hot 32GTR :woot:
Lol hot, not hot enough man... oh ya u are the guy with the number plate J Tuned :), im good. Was going to tell u about the hill but cant be able to find u on the last cruise, maybe next time will let u know in future if ya interested :D
mate was there in a white 180sx looks like a stocker, but with a front mount, but goes a bit harder than stock, specially when boost is wound up :)
maybe you saw him?
Mmmmm dunt think i saw that car. only saw the type x silver colour with 19 inch rims on it :woot:
Lol hot, not hot enough man... oh ya u are the guy with the number plate J Tuned :D, im good. Was going to tell u about the hill but cant be able to find u on the last cruise, maybe next time will let u know in future if ya interested :blush:
hehe im definately interested :)
well i rekon its hot, wish i had it haha
  • 4 years later...
An fascinating discussion is worth comment. I think that you need to write more on this subject, it may not be a taboo subject however generally individuals are not enough to talk on such slimming pills To the next. Cheers. get thin
  • Nope 4
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
