Hey sorry guys but I've posted this elswhere on the forums and mods can delete if I'm not allowed to do this but I have a problem and just wondering if anyone can help?!
http://www.skylinesaustralia.com/forums/in...howtopic=142432
theres the link to the page just seems people read different places to others so I thought I'd try you guys, any help is appreciated thanks for you time.
Tim.
https://www.sau.com.au/forums/topic/142443-r33-gtst-power-window-problem/
i had this problem and myself and lee (lbr33) tried to figure it out and still couldnt. i just ended up replacing the black motor box thingy and that resolved it using his power switches.
went back to mine and still didnt work... only to find out a few wks later that the plastic bits to push the button thing up and down were broken. gluing a piece of plastic back to it to act as the fork ended up fixing it.
pm me and if u want, i can have a look to see if its the same thing i was having with mine.
Yeah ive actually investigated alot and ive pulled the switch apart from the plastic mech ontop and you can move it around and stuff and you can still hear the black motor box just like a clicking kinda sound as i move the switch on the 3 settings, so im thinking it might be the motor box if so how much would that set me back to replace?
Can be one of 3 things padwan.
1. Window motor
2. Window switchs
3. Window relay
test each one.
thanks to Falconios fro helping me figure that one out :(
Hehe well i know for sure it isnt my switch but it could be my relay or motor, although how do i get to my motor to pull it out and check and stuff! Is this something I should DIY ?
Just got my car back from auto electrican today,and my motot in drivers side was screwed because of the auto switch. He reckons donty use aoto switch ever,always manually control the window urself. My switch is a bit broken,but all i got was a reconditioned motor,cost $250 fitted.
mine stuffed up because my auto switch is screwed,and when i use it,it stays clicked down which is why my motor burned out. Im not sure what a new switch is worth, but im over window expenses. As long as it works up and down i dont care about a switch. The guy reckobs his fixes about 3 skylines a week with the same prob as mine. Just so i didnt think he was rippin me off,i took it for a second opinion and he said exactly the same thing. So expect to pay atleast $250 for a motot fitted,as other places were $400-$500
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
