OK
i need to sell
OMP 4 point Harness $60
Turbo X BOV $150
Standard S14 Wheels $300
Standard Coils series 1 $100
Standard Coils Series 2 $100
Standard RB25 DET head Gasket $60 x 2
Starter Motor Manual $80
Bonnet Pins $20 x 4
R33 GTST Guards $150
R33 GTST Front Cradle $100 no shocks no brakes
R33 GTST Diff Cradle Complete Minus Suspension $300
Whole R33 GTST Standard Shocks $150
Whole R33 Brake Conversion (including Brake booster) $700
ARIES Forged Pistons $400 Slight Marking on 1 but nothing majour (standard)
Standard Turbo series 1 Perfect Condition $350
Standard inlet Manifold with injectors $120
Standard seats front n Rear $400 complete
R33 Strut Brace Second hand $50 (unknown Brand)
RB26 Rods $150 nitrated
RB25 DET series 1 ECU $100
GT35/40 Dump pipe n Inlet pipe including Filter with Air filter Cover $150,$150,$50 But all 3 for $300
WILD 1 MOTORSPORT Custom Plenium With XF throttle body $1100 Proven HP
Standard Bonnet White $150 X 2
K & N POD $50
Standard R33 GTST WING
Boss Kit Suit R33 GTST BRAND NEW $50
Second Hand Oil Catch Can With Speedflow weld on fittings,Return To sump and Drain $60
RB25 Standard Valve Springs $100
RB26 Standard Valve Springs $100
Standard RB26 buckets $100
Standard RB25 Balancer $100
Standard Turbo Air filter Pipe $50
Standard Inlet Manifold Including Injectors $150
Wreaking R33 GTST
(manual Conversion Sold)
Heaps is still there (most sold)
If you need something PLEASE SMS OR CALL Jason On 0424337243
Or pm (if you need a Quicker answer just call)Pickup Pefered but postage can be organised.Im usually up and down from sydney so can meet up there.
If you need any pictures Please Email Jason on [email protected] and STATE Part wanted and ill get a pict back to you.
Edited by MR331307
https://www.sau.com.au/forums/topic/142460-lotss-of-lotss-of-parts/
  • Replies 59
hay budy you have PM, but basically interested in the RB25 Ignitor, if it is to suit S1 R33 GTST and what condition is the ignitor in?. Also the Series 2 Coils, how many ks did they do and what condition are they in, any cracks or missfire. Posibly take the bonnet pins, is that $20 for 4? Also propably take the R33 Strut Brace. I live in Tas so i need to arrange shipping.
My mate might take the Harneses, will let you know ASAP
Mate i've sent you about 50 PM's, if you dont have the part you said you had can you let me know please.
yeah i sent him a pm last night as well when he was online about the ignitor but it seems he cant be bothered answering them
Mate i dont want to ruin your thread but i even talked to you on the phone and your still not answering my PM's....Ill just assume you dont have the parts ok.
Later
I dealt with jason last weekend, top bloke, no hassles, met me at the shop on a sunday and emailed me pics that i requested....
hes not always on a computer, so just give him a call.....
Just my opinion...
Just my opinion...
Thanks champ
And people i am working in a business so i am busy
if you Really need me call me
0424337243
Many people have dealt with me before
IVE HAD AROUND 100 pms
im still going through all of them
like i said if you want to call and pickup NOT A PROBLEM but if you need me to send picts might take 1 to 2 days as i am a very busy person.IF PICTS ARE NEEDED PLEASE PLEASE PLEASE JUST EMAIL [email protected] as ill get them done QUICKER.JUST YOUR FULL NAME SAU NICKNAME AND THE PHOTOS NEEDED.
Edited by MR331307
Im just cleaned up most pms
should make it easier
Once again
If picts are needed please email [email protected]
If you needa talk about something please sms or call Jason on 0424337243
Later
so delete your posts cuz you basically have....
i got pm replys almost instantly...and if not i wouldnt have kept sending them over and over...
Thanks mate
This bloke is telling me in his pms to get f**ked etc
who do i contact about him
as i havent done anything wrong
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
