i have a preety much complete r34gtt i am wrecking, it has 18" work rims with preety much new tread, factory privacy tint on rear quater windows and rear window, full red leather seats as well as red door cards and red highlights in dash, car is completely straight apart from front r/h guard strut tower and sub frame, i will sell it in pieces or i will sell the whole car to someone for 4k. pm me with anything you want of it or post below, pics below are before and after pics the front bar is stuffed but rear and side skirts would be ok with minor fiberglassing, has cat back exhaust system but one of the mounts on the muffler have bein cut and the tip is bent. if you want pics of anything inperticular let me know and i will get them up for you
https://www.sau.com.au/forums/topic/142473-wrecking-complete-r34-gtt/
Can i get the front eyelids if you have them.
Also do you have the flipdown din tray holder + double din facia.
Is it also tiptronic? has the steering wheel be retrimed? and what's the gear knob/pedals?
Do you have a 3" cat also? Anymore info on the cat back... And any close up pics of the damage to the tip.
Out of curiousity have you got any more pics of the seats and how much would you be looking for them?
Also what have you done with the rear spoiler?
Sorry for so many questions.
p.s. Looking at the damage to such a beautiful car makes me wanna cry man.
Edited by Howie
im looking for steering shaft, bonnet, right head lights and the braket under the right head lights and a right fender and a walshers water container thingy what ever its called if u have any of the things plz let me know the price and if u would send to perth and how fast.. i want pics of all the stuff if u have them
thanx might my number is 0423532992 if u want a fast sale call me 2morow
I'll take the GTR wing if it's available How much you want?
I'm also keen on the alternator assembly...
soz mate all that stuff gone
if you cant tell from pics bonnet stuffed right fender stuffed headlights stuffed, soz mate all got f**ked in acident
eylids, stuffed no din tray, was manual yes steering wheel retrimed standard pedals and no gear knob, i will get some pics of seats for you im afdter 3k for them and will through in the steering wheel, i think its a apexi exhaust will get pics up for that as well, rear spoiler gone
Hey I'm after these parts circled in red if you have them. Are they in good nick, not scratched or anything?
i think there fine ill take pics for you so you can see.
please don't trouble yourself with getting pics of the seats.. think i'll pass on them.
That would be good, thank you.
Hey mate pictuers of the areas in red would be great. :verymad: Where are you located?
And do you have this window trim bit highlighted in red? Its not the plastic pink weather shield but the rubber trim underneath it (like to the right of the red line for the rear quater window). If so is it in good condition?
Cheers mate!
P.S - is your boot trim in good condition too? I'm after the bits that go around the boot.
Edited by OnGsTa
heres the pics you wanted the scratches in the front on pic you cant see with the trim on, yes boot trim is still there and in good nick bit dirty but will cleen up, i also have the window seal if thats what you are after in the second pic
Edited by soslo_31
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
