After reading another thread and doing a fair bit of research i thought i would compile it for all members.
I can prove that its LEGAL to cut under that battery tray. (no more bullshit defects)
The act states if anything is done to alter the chassis it breaks the law, as your vehicle has been structually altered. Under the battery tray on an r33 there is whats known as a 'skirt' that is the 1mm thick peice of s/s, now if you refer to my above photo you will notice that this is connect to the chassis ( more then double the thickness of the skirt)
Obviously if you cut into the chassis you will no doubt weaken the structure of your vehicle, thats the reason its an instant defect.
There is no law in place in Victoria stating its illegal to cut into the skirt, its only a lack of knowledge that innocent people get pulled over and take an officers advice that what they have done is illegal, as police are respected members of the community and should be doing things correctly, not to line their pockets.
This is the act, the whole thing is relevant , but i highlighted the exact part i believe, as a skirt is not classified as a major body part and its not part of the chassis
and if i'm not wrong doesnt the GTR's pipe work go through here?
Take a look at the photo and then take of your front rim so you can see what i mean, you will realise its actually legal to cut out that part of the skirt. Anything under that red line CANNOT be cut, anything above is allowed, with that in mind make sure the hole also looks clean cut and doesn't look like a dog took a bite out of it.
Edited by R31Nismoid
https://www.sau.com.au/forums/topic/142546-defect-loophole/
yes i would also like to know where you got that info from. took my car to vic roads yesterday with this issue and the vehicle inspector had to phone up a few people to see if it was ok.
he came back and said we will accept a notice from your engineer saying that it is safe but you dont need a full engineers cert.
even with that document how can you prove the structual integrity of the vehicle hasnt been altered? you would have to test crash you car to prove it.
My engineer is welding a plate around the hole to strenghthen it so that he can sign it off knowing that it is as strong if not stronger than it was before i cut the hole. therefore the structual integrity hasnt been changed.
also it depends if you have airbags or not. if you cut a hole and have a crash and the air bag fails, what do you do then? they obviously did extensive testing on the car when designing it crashing it into walls and stuff to make sure the air bag would go off in such circumstances.
it might not be part of the chassis but its still in the crumple zone.
i mean hey if you can use that document to get out of a canary, great. but chances are the cops arnt gonna know if the structual integrity has changed and will refer you to an expert (engineer) to find out.
hope it works for you guys but i can drive a little easier having actual documentation for my specific car.
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2654526
here are a few links :
RWC:
http://www.vicroads.vic.gov.au/vrne/vrne5n...A256FD300241C38
What you can and can't do:
www.vicroads.vic.gov.au/vrpdf/rdsafe/vsi31.pdf
As for a lot of the other info such as what is part of the chassis and whats not and what can be modified, that has come from multiple engineers i know and one of them from car manufactor
how does cutting a 3" hole in the skirt effect that airbags?
Edited by mr_crust
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2654720
This is the critical point. These cars are of _unitary_ construction, which means that any structure other than the bolt-on panels (and some minor welded on brackets) contributes to the stuctural integrity of the chassis. The OP seems to be assuming that the rails themselves form 'the chassis' forward of the firewall, but in fact all of the inner guards and radiator support panel contribute to chassis strength and, as you say, the crumple zone. Modification (cutting) of any of those parts other than specified/allowed by the OEM _might_ weaken the chassis in that area.....which is the reason that modifications to any of those parts requires some sort of engineering approval.
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2655014
Unless these people were/are part of the engineering design team for that particular car or are a recognised VASS (in which case get them to sign it off), they aren't really in a position to judge. I know a lot of engineers that work for Holden and Ford plus a few that do conversions involving chassis mods and I'm confident they'd agree with what I've posted (before anyone asks.....no, I'm not giving out names).
Already covered.....it has the _potential_ to affect the structural integrity of the chassis forward of the firewall. Whether it will is up to a VASS to decide.
Anyway, I wish you luck (really) and am happy to be proved wrong.
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2655060
Wouldn't that be another hole right there if the GT-R has the piping running through the same section as has been suggested then it is a factory available 'modification' and perfectly legal.
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2655095
They are in a position to judge, even though they cannot sign off on the mods, they have the same qualifications if not more, they work on cars day in day out, unlike some monkey who works for the VASS who just signs off on it and collects a nice big payment.
The GTR has the sam chassis build as a GTS-T , its only got bigger guards and a different block, but the chassis is the same, meaning the cooler in the GTR uses a hole in the skirt, making this mod on a gts-t legal.
And as the act states 'cannot modify the chassis' it mentions nothing about the skirt being cut.
I would be intrested to talk to someone who knows the ADR's properly and can give me a definate answer, as most ppl on forums only know from word of mouth , and many police guess whats legal and whats not, and im sure many members can attest to that
Edited by mr_crust
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2655174
if these engineers you know can vouch for what your saying and put their name on the line and sign it off, then problem solved. :P if not then i dont think its gonna help. the only people that could decide wheather its altered the integrity of the structure is an engineer and if hes not willing to sign it off then it doesnt mean shit.
if he can and will then perhaps post up some details so people can get it in writting before there get canaried. :)
i really hope he can. i just paid $300 for my engineer to sign mine off. :D DOH!
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2656058
well the vass will look at your one, charge 300 bux and sign it off as safe, correct??? now why do you need someones signiture to make ur car safe, if they do nothing , or the most make a small bracket , and they can claim a small bracket will make it safe...what a load of BS.
im gonna do some leg work and find out more on this and try and get a certified engineer to give it the all clear & sign it , then post it up if i get it so fellow skyline owners can save a few headaches
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2656192
you would be doing everyone a big favour if you did. pity we didnt stumble on this last week. $300 bucks for a braket and a piece of paper.
:P
i know what your saying i doubt i even needed the bracket the pipe going through is 3mm thick anyway that should crumple pretty good. But as far as i know this was the only way to clear my defect.
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2656228
Nice one... :(
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2656900
if you had to clear the defect, it had to be approved , but hopefully in the future i can find out exactly what can be done and save everyone a couple of bucks >_<
i will update as i get teh info
https://www.sau.com.au/forums/topic/142546-defect-loophole/#findComment-2657955
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
