All,
I have come across a cache of Skyline bits and some various other parts. Please PM me if you are interested in anything, I will post this one up for some interest and update prices later once I know. I would prefer pick up from the north side of Sydney, most things are large and not post able but I will at a stretch. Buyer pays for postage.
Ok here we go.
1. Turbo’s (starting top right)
a. 2 x R32 GTR steel wheel & shafts which will need a re-build $75 Sold
b. 1 x R33 GTR which will need a re-build $75
c. 1 x R32 GTST turbo, working $200
d. 2 x R32 GTR turbo’s, working (The pair on the far right) $450 SOLD
e. (Bottom Left) 1 x NEW SR20 turbo $600
f. 2 x R32 GTR, has some wheel play $75 each
2. S13 Black Bonnet slight damage see 2nd pic $125
3. R34 White GTR Bonnet $500 SOLD
4. R33 GTST carpet $100
5. R33 GTR rear seat $250
6. R34 GTR Blue Bonnet Small scratch see 2nd pic $400 SOLD
7. R33 GTS Drivers seat Small tear see 2nd pic $75
8. R33 GTS Red Front Bar $225 (The Last pic)
9. R32 GTST White Front Bar $225 SOLD
10. R34 GTR White Front Bar $400 SOLD
11. R34 GTR Grey Front Bar $400 SOLD
12. R33 GTST SII Lower Front bar $175 Deposit Taken SOLD
13. New SR20 Front Bar $ 300
14. Nismo Original R33 Red 400R Rear Bar $300
15. R32 GTS Red Front bar $200
16. R32 GTST passenger Front Seat $100
17. R33 GTS side skirts $100 SOLD
18. Audi Quatro exhaust I Know who cares
19. Strut Braces R33 Front $70 each SOLD
20. R32 GTR 90mm zorst $75
21. R33 GTR Yellow Boot $150 SOLD
22. R33 GTS Jap roll cage $450
23. 180SX 90mm zorst $75
24. R33 GTR FMIC $300
25. R33 electric AE $50 SOLD
26. R33 Nismo GTS Rear strut brace $100
27. R33 GTS Passenger sear $75
28. Honda 900cc Fireblade zorst
29. R32 Muffler $75
30. R32 GTR gear box Blown 3rd $400
  • Replies 41
i dont think you have the pic of the R32 GTR front bar?
mind puttin one up?
Looks like I put 2 of the GTS's up. I will re-post as soon as I get back to work, the pics are there.
r the r33 side skirts painted or un painted? condition?
Unpainted and un-used. I could not see any cracks or anything, but as with everything, I would like everyone to view prior to buying, saves a lot of hassels
hey mate. ill take the side skirts off u. just 2 b sure will they fit a 33 gtst? wots ur address? would picking them up on saturday b good?
you got a bonnet for r32gtst? and gtr side skirts or mspec side skirts?
cheers,
daniel
No R32 Bonnet and the side skirts look GTR to me
pics of r32 gtr bumper? i would like to see it, all goes well i would like to give u money. hence please post pic asap.
I will repost the GTR pic on Monday when I get back to work.
looking for a white rear bar for 96 S2 R33. needs to be A1 condition. Also looking for Skyline boot garnish...Let me know if you can get your hands on anything. Thanks!!
Only what you see, sorry
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
