Have located a reasonable GTR here in Darwin one of the few drama's is the aircon compressor ( according to the current owner ) is kaput. He had it regassed but the compressor was toast, has anyone priced or tried to replace one not sure if local skyline aircon parts would be compatible thought I might pose the Question to see if any of the experts might know.
thanx in advance for any help u can provide.
:P
https://www.sau.com.au/forums/topic/142786-aircon/
  • 3 weeks later...
The coil tends to pull out of metal holder as the adhesive breaks down over time. Common problem. Do a serch for the things people do to fix em. Pull mine aprt to fix coil and shes been working fine, saved me $1500 for a new one.
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2715647
  • 1 month later...
sorry for the slow reply been busy got it checked out today an they reckon the compressor is definitly leaking this wouldnt be related to coil pulling out would it?
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2788825
Okay just Jap couldnt help turns out the zexel brand one I have is harder to get than the calsonic have found a mob in adelaide who have one offa gts4 that may do the trick anyone done this before and can confirm/deny that it fits
Edited by noone
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2795857
Contact an auto aircon company and get the compresor serviced/repaired...
chasing that option up 2morrow but read on here parts to rebuild are rare as hens teeth also, was in one of the sticky's I think about r32 aircon self diagnostics, thinking may even be an option to repipe modify pipes to suit, hopefully might find some sort of solution soon its damn hot at the moment.
had a look at your restoration post godzilla32 awesome work mate top stuff.
"The GTR is truly paradise for someone desperately wanting to empty their wallet" so true so true
Edited by noone
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2832539
"bleh air con is for pussy's. "
might think different if u lived in Darwin as I do. Nice to be able to demist windows when its pissin down rain too.
took it to another guy today and he checked it out and found it still had some gas in it just not enough, shows its good to get a couple of opinions, and find some one who is actually keen to do the job. Acording to this guy there is the possibility that an older leaking compressor especially one that has been left ungassed for a while the seals and such will dry up and shrink/contract a bit after a regas some of the lubricant soaks into these seals and gaskets allowing them to swell and OFTEN seal up again no guarantee's that it will but it can work that way. Seems to have worked for me though the coil is looking a bit iffy worked for most of the day before it tripped the fuse, will have to pull the coil and rewind or at least revarnish them as they are reading a little high compared with the 3.5 ohms (from memory) that the manual say u should see to earth.
Lucky there is a good howto on this very site showing how, to pull the coil, and I know the local motor rewinder helps a little too, :D
thanks to all who offered help or opinions
Edited by noone
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2833909
noone,
Try to find some one who can fill her with R12A gas.
When I bought the car it had R12 in it from Japan. The a/c was fine, nice and cold. The compressor was quiet and didn't really notice the compressor taxing power.
The car was in a small accident and the mob converted it to R134a. I got the car back and a/c wasn't as cold, the compressor was really noisy and I could feel it tax the power, then it blew a hose and leaked out. I also noticed when sitting in peak hour traffic it would cut the a/c. I fixed this by fitting a larger 14" thermofan that pushed a hell of a lot more air.
Apparently R134a is not so good from an effiency point. It runs at much higher pressures which is why I could hear my air con compressor and feel it cycle in and out and it also runs hotter, so the condensor works much harder.
R134a also has smaller mollecules so it leaks out quicker, R12a has larger molecules so slower leak.
I recently took it to a bloke here locally and he said to throw R12A in to these as the compressors don't agree with the R134A's higher pressures.
Since its been filled with R12A the air con is silent and I cannot feel the power tax, its also much colder. :(
Definitely happy with the R12A over the crappy R134A.
From memory the R12A ignites over 800degree's where as the R134A is around 300degree's.
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2837098
Cheers for that mate! As always i appreciate it :happy:
Some may recognise that line about emptying your wallet when owning a GTR as its from HPI GTR special edition. I liked it so i took it as my own hehe..
Im like you, if its hot you want to have the option to turn on your aircon. The car came out with it so in my mind it should work! Enjoy the GTR :(
Deren
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2837126
Cubes thanx for that info mate very interesting did notice that the car seemed to run heaps hotter with the aircon running, for the painfully short time it did. r12a being the older gas may be a little harder to find though these days think there is a guy in darwin who still has some so once I get the compressor clutch thing sorted might give it a go though specially if it does end up leaking again, kinda hope not.
Godzilla32 gotta give credit where credits due on your build an agree it came with aircon so getting it workin is worth it and makes the car seem unfinished/lesser if it isnt working, i think. Unless you have stripped it all out to save weight which is another thing alltogether
Edited by noone
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2844400
R12a is not too hard to find - Most workshops recover R12a keep it for themselves and fill the system back up with R134a and change the receiver dryer.
Im not sure what its worth to buy off them - but I would say it would be expensive - as is like any A/C work you get done to your car.
Cheers
Sumo
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2844413
R12a isn't the old gas R12 is, note the lack of A! :glare:
R12a is 100% enviro friendly unlike the R134a.
R12a is cheap, I had mine vac'd and recharged for $130. Alot here in Adelaide don't work with R12a, I believe thats because they need to be certified to work with it.
https://www.sau.com.au/forums/topic/142786-aircon/#findComment-2844773
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
