I bought this from Taso84 but to loud for my type of driving
pics can be seen in this thread http://www.skylinesaustralia.com/forums/in...=135826&hl=
will post, just want to get my money back so price is $90 plus freight
https://www.sau.com.au/forums/topic/142865-hks-pod-with-adapter-and-bolts/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
