hey guys im after info on how much amps would each of my fuel pumps draw, i got 2 044 external pumps and 1 intank 040.
im wiring them up and wondering what gauge wire to use from the battery to the single relay im going to run?
is a 60 amp relay big enough for the 3 pumps?
what wiring would be big enough to run from the one relay to the 3 seperate pumps?
any info appreciated regarding fuel pump wiring for my setup ;)
thanks
https://www.sau.com.au/forums/topic/142882-fuel-system-wiring/
Man thats a lot of pumps!
Twin 044's is enough for lots of power how much are you going to make?
And i would say you are better off with a 30 amp relay for each pump and the bigger the cable the better or the closer your battery is the better too. But minimum of 6mm2 cable or larger if possible.
single 044 is good for 400rwkw, you must be going for massive power?
if it helps the bosch ratings are
044 - 15.5Amps cont max current
040 - 11.0Amps cont max current
should be able to work your relay and fuse ratings from there.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
