G'day Megs how are you mate?
Yeah still going good. Fuel pump is extremely lazy though so I am limited to 10psi at the moment. Can wait to wind it to 13psi!!!Bought a SAFC today (old one) for $140. Are they hard to hook up at all?
Do you need to run aftermarket fuel regulator or can you use the stock one?
13psi?? cmon i wonah see 16psi :D
youre better off getting a bosch 910 i reckon. you dont need a regulator but an SAFC would be good if the fuel map is thrown out by the pump
so put on the pump, go to the dyno and check the AF. if its runnin hell rich invest in some sort of fuel controller
Its alright for you to say 16psi Adam cause you have a bloody big T04 dont you :D
Too late now on the pump, but I stick with my decision.Im slowly turning my GTS into a GTR.
I have the following so far;
GTR suspension
GTR cd stacker
Fuel Pump
I dont have to far to go before I put the GTR badge on hahahahaha
Hey Ben,
your list of upgrades should do the trick.
My old car had a GTR fuel pump, ECU and a adj fuel reg is also a good idea for your car.
13psi is sensible as standard injectors in my old car ran lean at 1 bar over 6000rpm.
I'm sure your next step will be bigger cams, injectors, adj cam timing gears and 1.2 bar of boost should make your car an absolute weapon....
its a nice change to see someone slowly build up their car sensibly with well thought out mods...... good luck dude..
hahahaha Christian beats himself hahahahaha
Akira I'm not paying anyone to touch my bloody car. It feels so much more rewarding when you spank a new v8 or a rexy with your own blood sweat and tears and more blood and some more tears and a little more blood and some..... you get the picture.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
