  • Replies 152
Posted Images
It's great to see you guys helping promote male heath; compared to the awareness of issues effecting the other half of our species we are far behind. On behalf of Kudos Motorsports I would like to support the cause starting with Adam Baldwin; he's supported us in the past and therefore it only seemed fair to return the favor.
From now till the end of the month I will donate 2% from each sale, $100 or over, to any SAU member participating in November that posts their rego number and name within the following thread:
http://www.skylinesaustralia.com/forums/in...howtopic=143721
Anyway guys to all those participating I cannot wait to see the end results, "mo" it up boys; we may only get a laugh now however one day the research funded from these donations may save your life.
https://www.sau.com.au/forums/topic/143129-movember/page/4/#findComment-2681879
+1.. that's a very generous offer :P
I've posted my details in the Kudos thread!
It's great to see the Movember concept spreading, I heard of it back in October but it has gained a huge amount of ground now that it's running. Last time I looked there were 33,000 people in NSW participating, next year is going to be HUGE.
https://www.sau.com.au/forums/topic/143129-movember/page/4/#findComment-2682750
