how much different is the total rolling radius (is anyone counting these)...
16in x 55 mm sidewall = 16 * 2.54 + 5.5 + 5.5 = 51.14 Diameter
17in x 40 mm sidewall = 17 * 2.54 + 4 + 4 = 51.18 Diameter
18in x 30mm sidewall = 18 x 2.54 + 7 = 52.72 Diameter
circumference = pi x D... work out the % diff by old circ. / new circ. These should all give you close enough to stock that your speedo will hardly be affected.
does this all sound like high school maths all over again?
and a smaller circumference will give you more acceleration, larger more top speed (if you could do it), same as a diff ratio will.
Keep the same rolling radius... easier all round, no issues with scrubbing, no issues with speedo.
BTW - my speedo is 6% out - as in it reads 94% of actual speed... with stock rims and rubber.
--ebola
--ebola
Too much maths and the wrong maths.You don't need to know the circumference as it's directly proportional to the diameter.Also it's not 55mm sidewalls.It's 55% of 205mm which is 112.75mm.Overall diameter of 205/55/16 is 63.19cm.
I worked out the differences for my own car. 235/40/18=64.52cm diameter.
Difference is 2%,so instead of indicating 100k's it'd show 98k's.
Stuff all.Not worth worrying about.
Oh yeah,235/45/17 is slightly less,about 1.8%.
Edited by wun hung lo
Or if you do want to measure the circumference you can try this method.
rpm/gear ratio/diff ratio x wheel circumference in kms x 60 = kph
example is my r 32 GTR
at 7000 in 4th gear ( 1:1 ) with 4.11 diff's and 18" 245/40/18 (2080mm )
7000/1.1/4.11 x .00208kms x 60 = 212Kph while the speedo was happily sitting on 195kph which is a brand new Nismo 320kph jobbie
Edited by tacker
:O:):)
and oops - pi x D, pi is constant.
and 55% means that my 205/55R16's are smaller than 235/55R16 wheels.... !?!?!?
then again, you are right that its *not* 55mm, so, umm, yeah.
205/55 is a fair bit smaller than 235/55.
The proper correct size which is only a TINY bit (</=1%) bigger than stock is 225/45R17, 255/40R17, 225/40R18, 255/35R18
Sometimes these sizes are more expensive than the usual 235 or 265 but then again, sometimes they are cheaper.
