that sounds ok - but technique is better like this
brake in high gear down toward where you then do your gear changes down just before accelerating in correct gear - skipping gears down is ok then (you could skip from 5th to 2nd so long as you come onto 2nd under acceleration.
That is so long as you let out the clutch in low gear at the correct speed with the accelerator down you can avoid tensioning your pistons.
The reason for braking in a high gear with the gear engaged is to get the benefit of vacumme assist braking. So doing your change down to 2nd from 5th 'after' braking makes sense if you are trying to take advantage of this.
but the point is don't brake with your foot on the clutch!
and remember to accelerate hard when you let the clutch connect into that 2nd gear at a road speed that is correct to give you acceleration in 2nd gear.
Downshifting has nothing to do with slowing the cars drivetrain. more like keeping it sped up.
Originally posted by dAVE
yeh - i got lost after the first few posts...
so was the article in zoom correct or not?.. im assuming not?
yeah maybe - depends how you look at it / read it I guess :)
Originally posted by fatz
i dont know if this is the same guy but  on one of the HPI videos there is a few "hot laps" in a r34 gtt around wakefield...
i will find out the vid number so everyone can have a cringe at the driving displayed
pete
So is it HPIv5 or HPv6 ?
Heel and toe is the gospel of race car drivers.... Mark Skaife is a good friend of mine and uses heel and toe in every gear change. Yes he may go 6th to 2nd, but he does blip the throttle to get it in gear.
Martin, when i last drove a V8 supercar, it doesn't go in gear without heel and toe, i'm sorry most road cars make this very easy by using syncros, heel and toe is better for a car than just cruising into a corner, sticking it in gear and reefing the clutch out into a nice compression lockup. Pete is right by saying whoever drove the 34 @ wakefield seriously needs some training in the heel and toe area as it was obvious that he had major compression lockup in a lot of corners.
And if you've driven any performance cars lately, they prefer to be in gear under brakes, as it makes the car a lot more stable.
If you care to argue, please call any race driver.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
