25's are double synchro just like the 26, both boxes use the same synchro's, bearings, rings, etc
internally the only visual difference i saw was the input/main shaft looks a little different, 26 is thicker in some places, i've been told that the gears are the same as well...
there may be other little differences but basically the same,
25 boxes are very rare these days, drifter love em, so you could probably buy a 26 box and change to internals over to the busted 25 box, was considering this recently but decided against it, by part numbers most parts are the same but making parts fit is a different story...
has any1 tried this? ive heard a few but no one willing to share secrets
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2683337
There are plenty of boxes around.
Its just people arent prepared to pay the asking price for em :wave:
But GTR boxes go for almost the same as RB25 boxes anyhow. Usually only $100-$150 in it
about a month or 2 ago when i was searching....
Sydney wreckers were asking $2000, Brisbane $1500... no stock in both states!!!
found a R33 GTR box in Brisbane was $1000... with warranty!!!
also found a lot of ppl trying to pass rb20det boxes and rb25de boxes off as r33 turbo boxes so be careful
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2687593
The z32 vg30 boxes are the same also..i put one on my rb30det..just got the front (bell) section off a broken rb26 box and bolted it on.rear extension housing is a bit shorter but a rb25 one will go on if you want,i didnt bother im just using the vg30 one.Im making over 500rwhp and havnt had a problem.EKW in melb sell vg30 boxes for $550.
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2703152
yeah exactly the same box..I've run full slicks on mine and launched it pretty hard and ive never had a problem.Admittedly ther would be a bit less stress on it because its in a fairly light 240z but i cant see it breaking..Same part code as rb25/26 boxes
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2703486
They had a few at the time but that was over 6 months ago..not sure what year,they are all the same as long as its from a z32.Also i got one out of a na because they are both the same and i figured the the turbo ones would have copped more of a hard time than the na.
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2704046
think i remember seeing brand new 25 boxes for 3500.. id much rather buy new than pay 2grand for a 2nd hand one that is 'supposedly' good condition!
also i have a 25 box with GTR internals but i didnt do the swap myself so i dont know if there are any complications regarding swapping. Seeing as the OS cross mission set drops straight into either box, id say it would be straightforward?
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2717706
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
