25's are double synchro just like the 26, both boxes use the same synchro's, bearings, rings, etc
internally the only visual difference i saw was the input/main shaft looks a little different, 26 is thicker in some places, i've been told that the gears are the same as well...
there may be other little differences but basically the same,
25 boxes are very rare these days, drifter love em, so you could probably buy a 26 box and change to internals over to the busted 25 box, was considering this recently but decided against it, by part numbers most parts are the same but making parts fit is a different story...
has any1 tried this? ive heard a few but no one willing to share secrets
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2683337
There are plenty of boxes around.
Its just people arent prepared to pay the asking price for em :wave:
But GTR boxes go for almost the same as RB25 boxes anyhow. Usually only $100-$150 in it
about a month or 2 ago when i was searching....
Sydney wreckers were asking $2000, Brisbane $1500... no stock in both states!!!
found a R33 GTR box in Brisbane was $1000... with warranty!!!
also found a lot of ppl trying to pass rb20det boxes and rb25de boxes off as r33 turbo boxes so be careful
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2687593
The z32 vg30 boxes are the same also..i put one on my rb30det..just got the front (bell) section off a broken rb26 box and bolted it on.rear extension housing is a bit shorter but a rb25 one will go on if you want,i didnt bother im just using the vg30 one.Im making over 500rwhp and havnt had a problem.EKW in melb sell vg30 boxes for $550.
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2703152
yeah exactly the same box..I've run full slicks on mine and launched it pretty hard and ive never had a problem.Admittedly ther would be a bit less stress on it because its in a fairly light 240z but i cant see it breaking..Same part code as rb25/26 boxes
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2703486
They had a few at the time but that was over 6 months ago..not sure what year,they are all the same as long as its from a z32.Also i got one out of a na because they are both the same and i figured the the turbo ones would have copped more of a hard time than the na.
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2704046
think i remember seeing brand new 25 boxes for 3500.. id much rather buy new than pay 2grand for a 2nd hand one that is 'supposedly' good condition!
also i have a 25 box with GTR internals but i didnt do the swap myself so i dont know if there are any complications regarding swapping. Seeing as the OS cross mission set drops straight into either box, id say it would be straightforward?
https://www.sau.com.au/forums/topic/143333-rb26rb25/#findComment-2717706
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
