This morning i was putting to work when a fourby hammered past, flicking a rock which put a lil crack in the corner of my windscreen. Which, over the course of about 5 minutes, spread down and in to just about the centre of my windscreen. Its beyond repair - has anyone had to replace their windscreen, or a windscreen on an imported car in general???? should i buy glass that ive seen on yahoo japan and have it sent over then fitted??? or can they get the glass for stageas here?
https://www.sau.com.au/forums/topic/143386-anyone-cracked-their-windscreen/
I had to replace my GTR windscreen after I put my fist through it :)
Easy job though, did it at Obriens and it was covered by insurance.
much of a wait for the glass? and what year GTR? Cos skylines are pretty common now, but stageas.... arent....
Within 2 days of owning my current R33 GTST my window suffered the same fate. (June this year)
$220 fitted at O'Briens - insurance then reimbursed me. They fitted the same day too - got one of their guys to go to the Newcastle warehouse and get one for me!
That's pretty cheap.. Did they come to your house? or You went to them?
I got quoted $450 for a new windscreen. Think one of the NSW SAU members paid $400 for their new windscreen from obriens too..
I went to them....seeing as its only a 5 minute drive from my house!
I had a hole in the window from a rock on the F3 - got home parked in the garage, went out the next morning to get the hole repaired - soon as the sun hit it cracked the whole way across and was not fixable anymore :O
They were pretty good though - went in about 9.30am and they said they only had them in stock in Newcastle sooooo they sent a driver up there to grab one and dropped my car back at 1pm to get fitted.
*** just checked my receipt and was definitely $220 fitted - maybe they made an error when they quoted me? ***
Do a search, ring up Novus in Burpengary dude, they did mine just after I bought mine about a year ago, dunno how much it cost, was covered under insurance, but they alluded that it was no more or less than avgerage falodore.
hmmmm might insure the bastard THEN make some calls
alternatetivley i could get a couple of screens over from yahoo auctions, have one fitted and keep one as a spare in case it happens again, or i can sell it on when it happens to someone else i guess. Most of the cash just goes on shipping.
  • 7 months later...
Just to dig up an old thread, I got a nice crack in my windscreen on the weekend. Started out as just a small 2 cm crack but being 3 hours outside of Brisbane and doing 110 caused it to become about a 30 cm crooked crack in no time at all :thumbsup: Now I have read the other threads and it seems that Novus in Burpengary are the guys to go to. My question is that I can see a black dotted strip around the outer edges of the windscreen, and isn't the switch on the dash to the right of where the ignition is some sort of windscreen defogging or defroster (for ice and such), the one you puch once to turn on and once to turn off and has a little orange light on the top of it. If I'm right is that black dotted strip anything to do with that and if it is do the aftermarket ones have them.....just curious, and if I'm wrong about that button what the hell does it do???
Edited by Mr_RS4
Nah to the right of the ignition key barrel. I wasn't sure what it did, the only reason I thought it was something to do with the windscreen was from reading the factory japanese manual I have and going by the pics :dry: And yes I know the a/c heated air is to demist.
anyway as long as it has nothing to do with the windscreen or those little dotted black lines have nothing to do with anything then I don't mind getting an aftermarket one. Thats my only concern. Can anyone tell me what this switch does then??? :dry:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
