Hey all,
For sale is a surge tank setup with a Genuine Bosch 044 pump and all fittings needed. The tank is a 2L polished RPM EFI unit with 3 dash 6 fittings at the top and one dash 8 fitting at the bottom for the pump to feed off. The fittings on it are the Proflow Engineering fittings and the pump also has its own anodised bracket.
Everything here is brand new and unused, only pulled out to see what it looked like!
All thats needed to get this setup going is a bit of hose and 12v!
NOW $500 for everything here, im also willing to separate but prefer not to.
Located in Melbourne, I dont mind posting.
Thanks!
Mat.
0400 558 030
Edited by femno
https://www.sau.com.au/forums/topic/143583-surge-tank-and-044-pump-setup/
  • 1 month later...
  • 1 month later...
Sorry for a possibly dumb question but what will a Bosch 044 pump flow Hp wise. I need 600hp pump at least for my current application.
Thanks
The 044 will flow up to around 600HP as far as im aware, maybe a little more. This setup is a must for any highly modified vehicle to eliminate any possiblity of fuel starvation.
044 for sale: click my sig link.
All still available.
Hey. I am in the United States. I have calculated shipping costs via EMS from there to here. I will give you $575 AUD shipped to me for it. I have money in hand and can pay by what means you prefer. Thanks for your time.
Edited by Ramius83
  • 1 month later...
Do you have any more info about the surge tank? Manufacturer / Model?
Yes it is an RPM EFI branded surge tank, 2L capacity with dash fittings. Polished Aluminium.
  • 3 weeks later...
  • 1 month later...
  • 5 months later...
  • 1 month later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
