hmmmm, interesting???
jus read that the sonsor shud be on the top hose, mine came with the car wen i got it but its on the bottom hose, is there any logical reason why its there, wat difference wud the top and bottom make??
is it hot engine coolant coming out the bottom hose through the radiator and out the top cooler or the other way???
the top hose is generally the water coming out of the engine, so its a better representation of internal water temps. where as the bottom is water coming out of the radiator, which has been cooled.
wat wud u rather kno ........????
temp of hot water out of engine, to make sure its not rising too much inside there OR temp of cool water goin in the engine to make sure it is getting nice cool water.
the factory sensor is on the top hose so u already have the stock temp gauge there. i also got a oil temp gauge so in my case i'd rather know my radiator is working and sending in cool water to the engine.
anyone got other theories....
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
