Also a manual tailshaft to suit a r31
will see what ive got of the 2 rear bars i have atm
as for tailshaft, mine will be available very soon mate :happy:
WTB
RB25DET gearbox, preferably good condition (read: must not be f**ked otherwise it will be returned via a front window!)
PM me with what you've got and what you want for it
NEED THE TAILSHAFT YOKE FROM THE BACK OF THE BOX AS WELL (if possible) :)
Is DET mani yes? Can see myself grabbing that off ya at some stage. Let me know when ya get it back together - no rush.
yep sure is DET mani
ill get the rest of it back off my mate sometime this week i reckon so ill just send you a pm when its all back together :)
Chasing a new set of wheels lads.
Must be something along the lines of 18x10 +20 or similar. No x7 +5 or anything lol.
To suit a GT-R, Work meisters, emotions, etc etc. Hit me :P
http://www.skylinesaustralia.com/forums/Wo...22-t290719.html
as for tailshaft, mine will be available very soon mate :D
WTB
FOUND ONE :(
PLEASE DELETE
WTB
Nice, just give me a pm when your ready matty :(
After a set of either 17s or 18s that at least 9" wide, (prefer the same all around, but 9" wide at the front and 9.5" or 10" wide at the rear in ok too) in GTR offset. Cheaper the better.
PM.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
