WTB :
Drivers side Front indicator for a 32, the clear ones preferably, doesnt need to be tho. And if u dont want to split the pair, may consider buying both depending on price.
Also, I'm needing a globe holder that holds the H1 bulb in the 32 headlights. Yes, I have the shit 32 headlights.
Funny fact is that a 4 door R34 is NOT the perfect family car - my S15 even had more room for a baby seat in the back - and my V35 KILLS IT. When Tyler was little and in the back of the 34 he could easily reach the back of the drivers seat to kick and annoy the piss out of me. However in the V35 there is literally a foot between his feet and the back of my seat. Go figure.
I attempted to have passengers in the rear of the R34 a few times (once for a wedding), and the driver and passenger front seats have to be stupdily forward and nearly touching the dash to even fit legs in the back. Poor design for sure (but sexy cars, no doubt).
i beg to differ though andrew, the 34 backs are pretty spacious, ive had 3 fatties in the back but the s15 if someone was in the back they had to put their feet in the opposite footwell to be comfy...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
