Ive been looking around in tutorials and searching, cant seem to find anything useful.
Well ive finally brought some clear NISMO side indicators for my R33 off ebay :sorcerer: but my problem is I donnno how to put them on :huh:
Ive seen quite a few ppl from WA who have clear indicators and was wondering if you guys can give me some steps of doing this. Things such as how to take off my current side indicators and changing my bulbs around, i guess that the new indicators just clips in?
Thanks any help would be great!
https://www.sau.com.au/forums/topic/143788-r33-side-indicators/
Easy man! just wedge ya fingers on one side and sort of slide it to the otherside a bit and pull out towards you, it clips in. It's easier from there on.
You can also get the silver globes that illuminate orange, so you don't see the poxie orange globe through the clear covers, I got mine from little accessory shop in the city next to Hoytes on Murray st.
Good luck! :huh:
Here is a basic instillation guide:
Place pointer & index finger at the rear of the indicators unit (door end)
Apply forward pressure and pull out of guard
Remove bulb holder by turning anticlockwise, replace bulb with new orange; reverse process with new indicator unit.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
