i was thinking of going....
anyone know if its on and anyone else plan on going?
Yes, it's on tomorrow (weather permitting of course)
quick question...what if the car is not registered in you name? what sort of identification or letters are required?
Everything you need to know is on this webpage (taken from Wed Street meets, but same rules apply for Friday)
Good luck :(
yeah i'll be there trying to improve my 60ft's, and race my mates wrx FINALLY hahaha...
hopefully get him off the mark because his too scared of destroying his gearbox and granny shifting.
i'll say hi if i see your SERIES 3 GTR there hahaha
ill be there...got some used semi slicks to get use to and to get my time quicker...cant wait to have a look at ur GTR....if you dont mind me haveing a look. what mods do u have and power and est et?
It was an awesome night in terms of weather and turnout. It was a shame that i couldnt get to see all the other cars race. (congrats to 1jz747 on what looks like a personal best) Thanks shortie for the tyre pressure gauge, someone could of told me that i had to clear the memory function before i let one of my rear wheels down to 3psi bwahah.
HKS GT-SS Turbos
HKS dual Dump and Exhaust system
HKS air pods
HKS intercooler
Tomei Poncams/Gears
Sard 700cc Injectors, rail, and reg
Nismo Fuel pump, intank
Splitfire coils
Power FC and AVCR
Power output is 340rwkw @ 8,000rpm @ 1.5 bar BP ultimate fuel
Last night ran with 370rwkw on a race tune :rofl:
Edited by HKS26T
HKS GT-SS Turbos
HKS air pods
HKS intercooler
Tomei Poncams/Gears
Splitfire coils
Power FC and AVCR
Last night ran with 370rwkw on a race tune :O
Congrats mate, What was your 60ft and mph? Good to see mate! :)
Congrats on an awesome time HKS26T, was that with a stock motor? Who is your tuner? I think you've convinced me to go buy a 33 gtr lol
First time racing at the strip? I'm surprized they did'nt tell you to go home as soon as you got into the 11's let alone 10's.
Edited by bmxwrx
Thanks mate. The Bottom end includes forged pistons, standard rods, head gasket etc. My tuners are Dave Haak (by appointment) and Adam Neish @ JEM. It was the first time for the car at the creek. The officials were great.... i think it was aaron i spoke to...he asked me to turn down the boost a little and i could go back out :mellow:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
