if any knows of a non turbo r32 or r33 let me know been looking for a while prefered colour black but will look at others needs to be in gud condition and no major mods wheels and exhaust is fine
needs to be in gud condition and in or near sydney
message me over the forums or send an email to [email protected]
Edited by dyken
https://www.sau.com.au/forums/topic/144368-wanted-r32r33-manual-non-turbo/
its what im looking for the silver im not sure sure of but thing is im not going to travel far for a car im not goin to travel far from sydney ive got to much school work to do to go somewhere far to inspect test drive get an inspection from state roads or nrma etc
Hi i got one for sale.
R33
1995 mod GTS25 Type S. (they are rare)
Sun Roof
full Zorst
17inch Rims
Dark Tint
Full Pioneer Sound system
Perfect Cond In and Out
135XXX km
Lowed Kings Spings
5 Speed with Nismo Short Shifter
Immobiliser (spelling)
LSD (only with the type S)
AWS
Rear Wiper
Drivers Side Air Bag
VCT engine
Wine Red In colour
Number Plates GT52NV (GTS2NV)
$12.500 ONO
located on the Central Coast.... About 1h to 1.5h from sydney.
PM ME for pics and more info.....
if interested :(
got a white one series 2 with less than 70,000 on the odo after 15K for it mint condition interior and exterior only changed the body a tiny bit with a series 1 bonnet so i could fit a msports front bar other than that u can check the engine vin and all the other numbers to confirm its a s2 also has 18" chrome rims which are brand new and it also has a 3" hks super dragger exhaust and its non turbo im having a conversion done to turbo which wont be started for a few days yet so i can always stop that and sell off the parts :P
Edited by DaGr81
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
