Bloody Hicas!
I had the same problem, so i opened the power steering fluid, made sure the filter on the stick was clean/not impeeded, swirled the fluid with the stick, and gave it a top up. No light anymore. give it a try. Would not have anything to do with boost.
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-293324
Screw the diagnostics...Remove the hicas altogether...I promise you the cars handling will astound you without it...If you are intereseted I can supply a rear replacement bar out of chromoly for a very reasonable price...You can have a look at my car at some stage if you like.
One of the best things you could do for your handling.
Cheers,
Russ
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-296567
haven't seen the r31 ones before but they are very easy to make, Have to have a look and a measure...thats all. Is it hydraulic like the r32?? I also took out the lines and capped the pump up the front....It never shows as an error etc and the fluid just circulates around like normal....
cheers,
russ
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-297354
Only because it masks inherent problems, like chronic understeer...once you set it up and have the hicas removed it is much faster around the track...
Also much less weight and less to go wrong..I know its small differences but it all adds up. The car feels much more direct and respnsive to throttle steer without hicas.
Anyway, each to their own...Just make sure you drive both before you finally make up your mind.
Cheers,
Russ
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-302072
I would suggest if you are happy with your car then leave it as it is...if you are not then you need to decide how you drive...do you drive hard..not so hard?? What other suspension mods do you have or are you prepared to do...
Give me a call if you want..pm me and I'll let you know my number, I can probably help you to decide.
Talk to other people who have and those who have not and see what they have to say...read these forums...heaps of threads with people who have problems with hicas..one thing is for sure no hicas is no worse.
Cheers,
Russ
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-302142
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
