Just got badged!!
Dirty F***ers!
I was at my GF's in Chipping Norton and was only away from my car between 6pm and 8:00pm and the the bastards hit me front, back and sides! They've jimmy'd the boot lock out and screwed the boot. The rest of the paint work looks ok...
I'd spent the whole day driving around the country side getting quotes on bits and pieces for my car and had made a few fixes to the point where I was extremely happy with the days achievments... and this goes and happens. I know they were there this morning and the car was only left unattended for about an hour while at Warringah mall having lunch. I'm positive they were there then!
Man! I am sooo dirty! :goddam:
I called the cops and asked if there was anything i could do about it and they pretty much said it wasn't worth their time... Making a report and taking it down to the station shortly... Won't be worth claiming on insurance, the excess will be heaps more than the cost to repair...
I'm also writing a letter to the units' manager requesting better security and to repair the flood light that is sitting there broken for months... Apparently there has been other occurences of this sort of stuff going on around the area.
How brave are they though!? only a couple of hours with people coming home all the time and driving into the lockup parking either side of the visitor parks...
Does anyone know a good place around Sydney (pref. West) to replace these parts. Nissan dealers and Justjap spring to mind. Any ball park figures of what I'd be looking at? at least a couple of hundred I'd presume for the front SII badge, 2x GT badges and new lock for boot.
Anyone else had this happen? Did a search through the forums and noticed that a guy in Perth had gone through the same thing and had posted. Presume that it's pretty frequent.
I'm off to make a nasty poster to stick to the wall where my car was parked... Feel a BIT better now i've got that off my chest. If anyone, by some very small chance, hears about anything to do with this, I'd be very appreciative... :box:
https://www.sau.com.au/forums/topic/14460-badged/
Thanks for the suggestions guys. In Surfers atm. This happened the night before I left, so it put a bit of a dampener on things. Will sus it out when i get home.
I'll be keeping a look out for that white van Brody. You live around the area?
There's 2 other skylines that live in the complex. That reminds me, there's skylines everywhere up here! Have especially seen a heap of done up R31's.....
https://www.sau.com.au/forums/topic/14460-badged/#findComment-296660
Originally posted by benm
I'll pay good money for you to bring a fine  tanned blonde qld chick back to the office Knat !!
Two in the bush! :)
Don't think the GF will let me and one won't fit in the suitcases as they are already filled with girly clothes etc. :)
https://www.sau.com.au/forums/topic/14460-badged/#findComment-297725
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
