sandwich plate can be used for any oil sensing application...
i use one for my oil pressure gauge
go to www.justjap.com and get a "sandwich plate" for $30 or so:
http://www.justjap.com/parts_ngauges.htm (its the last one on that page)
that allows you to screw the oil pressure sender onto that
then, screw that in between your oil filter and block and wire it up!
i have attached a picture of the sandwich plate with OPS attached when i did it on my car. hope that helps!
cheers,
Warren
I have that as standard on my car for the stock gauge. Surely you can just run it from the original sender (providing its accurate). Dont all RB's have a similar sender unit for the stock gauge? Either that or remove the (possibly dodgy) original sender and fit the new sender into the original location. if need be you can splice the original gauge in with the new ones wire so both work...
Edited by Godzilla32
you can't run it from the original sender.. that's what is the problem with the stock gauge
and if you remove the original sender, then you will lose the stock gauge functionality - yes it doesn't work anyway, but it has a "low pressure" light that does work and is useful to keep going
so really going a sandwich plate is the only option to keep the standard gauge and the low pressure light, whilst also being able to run an additional gauge.
Deren, when you say "you have that as standard" do you mean the sender itself, or the sandwich plate? i wasn't aware of any cars that came out of hte factory with a sandwich plate for any of its gauges..
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
