hey guys
i just bought a set of gt2560rs -5 for my gtr
just curious is it as simlply bolt the old turbos off and on with the new ones, do i need to modify anything??
also can someone please list all the gaskets i need??
and one more question my engine istock with no other mods beside, full exhaust and airpods, is alrite to run these turbos at 1 bar??
thx guys Ali
https://www.sau.com.au/forums/topic/144752-gt2560rs-5/
thx for that guys, y do i need to drop the boost?? and also wat do u mean by slot the oil drain bolt?
thx again
Those turbos flow more alot more air at 15psi than stock ones. More air but, only the factory fuel and ignition maps that are suited for the smaller turbos. The factory ecu does run fairly rich usually so you have a little head room for power but, those turbos have a fair whack more power potential than you have margin for error. The main issue may not be right up top either but, rather the peak torque point which on those more efficient turbos will possibly be higher than factory at the same point the factory turbos make peak torque.
Bottom line is you don't want to go guessing that 15psi will be good clean fun. Get the boost right down as low as you can and then throw it on a dyno and see what you can take it to boost wise without getting yourself a Power FC or S-AFC ,at least something. You might be able to run 15psi but, without taking it there under dyno or O2 wideband observation you may find a new bill sitting in your engine bay.
https://www.sau.com.au/forums/topic/144752-gt2560rs-5/#findComment-2704258
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
