hey guys
i just bought a set of gt2560rs -5 for my gtr
just curious is it as simlply bolt the old turbos off and on with the new ones, do i need to modify anything??
also can someone please list all the gaskets i need??
and one more question my engine istock with no other mods beside, full exhaust and airpods, is alrite to run these turbos at 1 bar??
thx guys Ali
https://www.sau.com.au/forums/topic/144752-gt2560rs-5/
thx for that guys, y do i need to drop the boost?? and also wat do u mean by slot the oil drain bolt?
thx again
Those turbos flow more alot more air at 15psi than stock ones. More air but, only the factory fuel and ignition maps that are suited for the smaller turbos. The factory ecu does run fairly rich usually so you have a little head room for power but, those turbos have a fair whack more power potential than you have margin for error. The main issue may not be right up top either but, rather the peak torque point which on those more efficient turbos will possibly be higher than factory at the same point the factory turbos make peak torque.
Bottom line is you don't want to go guessing that 15psi will be good clean fun. Get the boost right down as low as you can and then throw it on a dyno and see what you can take it to boost wise without getting yourself a Power FC or S-AFC ,at least something. You might be able to run 15psi but, without taking it there under dyno or O2 wideband observation you may find a new bill sitting in your engine bay.
https://www.sau.com.au/forums/topic/144752-gt2560rs-5/#findComment-2704258
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
