Guest INASNT
Check out the Geremy Clarkson vidz on this site, for those that dont know him hes the host of top gear a uk car show.
The first 'no limits' vid has a Jun 1000hp R33 at the end which Jeremy fangs around an airport runway. Its the fastest road registered car in the uk being able to do 0-100 in 2.5 seconds.
http://carfreaks.b0nk.net/
Havent seen the other vidz, downloading now, but they will be farking sick 2.
If u are on 56k dont bother coz each file is a dvd-rip and are about 650mb each.
Enjoy
https://www.sau.com.au/forums/topic/14485-jeremy-clarkson-vids/
  • Replies 55
Originally posted by darK
i'm d/ling them and burning them for denham as we speak..
so.. maybe we can figure something out jay
Yepp, no worries.
Just the BIG ones (150+ megs) I'll grab off ya. The others I'll download over night with Download Accel. Should only take about 53 months !!!
Damn dialup :P
u want the "Jeremy Clarkson" ones yer?
Yepp :uh-huh:
I'm going to download the smaller ones (less than 150meg) that are in the root directory just to see what they are about.
There's also a few big ones in the Best Motoring directory.
I've had those 4 movies in DVDRip-DiVX format for a month or 2 now ;)
They are quite an interesting watch.
Edit: Just noticed the 'Best Motoring' rips, they'll be tonights download ;)
/slaps his ADSL Modem smoking with 30gb/mth.
Guest INASNT
how fast are u able to download with your asdl? I was getting 80+k/sec with my optus cable.
How much u paying for asdl and with who? i wanna change over 2 as 3 gig is fark all per month.
54k/s
$99.95/mth with Internode on the 512/128k FlatRate doing around 27gb/mth.
Getting 220k/s from this http site.
