Just fitted pillowball strut tops and in the paperwork that came with them it says they need regular maintenance but doesnt say what is involved in doing the maintenance. Im guessing just a bit of light oil around the ball is about all thats required. Anyone have any info? Also how long should I expect them to last before they need replacing?
Cheers
https://www.sau.com.au/forums/topic/144892-pillowball-maintenance/
Cheers
Remove the spring/shock units from the car
Remove the strut tops from the spring/shock units
Wash the strut tops in kero
Dry thoroughly with compressed air
Make sure there is no dust, grit or dirt in the spherical bearingss
Lubricate with white (moly) grease
Check the operation, if loose, with free play, then replace the spherical bearings
If smooth in operation
Replace the strut tops on the spring/shock units
Replace the spring/shock units into the car
:) cheers :)
oh ok, thought it was going on a skyline...
i guess if you were to line everything up again the same on the strut tops you should be right on alignment, but to make sure it hasn't changed I would think an alignment check would be good
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
