  • Replies 103
Guest INASNT
Originally posted by rev210
I found out I'm not to blame for being an idiot self tuner.
The problem (knock/ping) seems to be a single piston issue. We suspect a blocked injector or two. The afr's are super rich as I have previously dialed in more fuel to cushion any potential damage.
The result was a ping at about 4700rpm that prevented us reving it any higher.power: 230 rwhp - afr : high 9 with very little timing advance
170odd rwkw with 9 a/f ratio?? so ur car is a freak then!:D
Dave,
230rwhp (172rwkw) @ 4700 is bloody impressive! Given that peak power isn't till 6800 stock. If you've dialed the HKS cam gear for more top end then the peak might be even higher?
My estimate of mid 190rwkw is lookin' good :mad: It might go even higher!? Especially when you're running conservative timing & nasty rich.
While on the A/FR's, 9:1 isn't very healthy @ all :) You might have dialed in a little too much cushioning! Not quite as bad as too lean, but still not good.
Originally posted by INASNT
170odd rwkw with 9 a/f ratio?? so ur car is a freak then!:mad:
Yepp, just as we thought, Rev's got one of those freak 1995 cars :uh-huh:
It's good to see that the ping issue 'shouldn't' be anything major.
Are you getting them cleaned using the ultrasonic bath way?
Once you get the ping sorted, and back for a re-tune, I reckon you'll see your 12 second pass :uh-huh:
Well done
J
It's not a freak car.
The first dyno it ever had (over 2 years ago) showed 180 rwhp odd on a dyno day with other cars and whilst a heathly figure it wasn't the highest.
the mods and tuning I've done are responsible for the power and considerable torque it's making (afr's uptop aside).
Mine's a 95, but it's no freak, hell I can't even pull the 1/4 in less than a 14 right now... so bleh!
considering dave ran a 13.4 without the AFC, i still cant see what i'm doing wrong...bleh!
Originally posted by EnricoPalazzo
So let me get this rite? 170rwkws at 4800RPM????
DAIM.
Pretty respectable figures considering engine mods are turbo back exhaust, panel filter, thermal wrap, 10psi, cam gear, afr of high 9's (untuned s-afc), and a little advanced timing (did I leave anything out?).
I'd be happy with that, that's for sure :D
Most people get less than that with a 'professional tune' at a workshop :)
Rev - are you getting the injectors clean by an ultrasonic bath?
Cheers
J
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
