have 6 550cc injectors they all just been cleaned out n tested so they are ready to go . they are in excellent condition .grab a bargain
$600
sms : 0421047935 or [email protected]
Edited by iwon
https://www.sau.com.au/forums/topic/145025-550-cc-injectors/
hi mate yes they are denso injectors and no they don't have the plugs if you mean the ones that go to ur engine loom . they bolt straight into rb20 and plugs are the same ,rb25 , rb26 u'll need custom rail
They are denso injectors, do they come with plugs?
these dont go straight into standard plugs you need to get oval denso plugs there about $18. each.
been there tried that trust me they dont sit well. these are a great upgrade for the rb20 not 25s
If your looking for $600. dollars you will be holding onto them for a while
Edited by RB-ONEVIA
mate stay out of my topic if you not interested sick of people butting into other people topic thinking they know it all . you will be reported to administrator thanks
just letting people know that they need the denso plugs for the injectors thats all
if i really wanted to wreck you post i would tell them where they can get them from, just stating facts
Edited by RB-ONEVIA
mate you won't find denso 550cc injector cheaper then $100 each your dreaming . u can't even buy stock ones for rb engine for that price so pull your head in and stay out of here
hi mate yea just had a loo kand last 4 numbers says 2020 . thanks alot that should hopefully sell them quicker .
if you look at the part number and they ahve 2020 as the last numbers they are high impeance and they are 550cc from an Rx7.
Good luck with the sale.
hi mate my mate had them in his rb20det and he said he used the stock plugs for it . and they bolt straight into stock fuel rail
do u need the plugs if there were to go in a rb20??? these low or high independance??
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
