Apprently. Was thinking about picking one of these up, for reasons fairly obvious.
Do they work, has anyone got any experience with one of these....?
Cheers guys.
Rob
http://www.skylinesaustralia.com/forums/in...howtopic=137584
https://www.sau.com.au/forums/topic/145188-hks-eids/
Cheers guys.
Rob
i've got one of these from ebay...but i dont intend to use it...its on the SAU sale forums. PM me if you're interested.
Being from HKS im sure they work fine for what its supposed to do unless of course the problem is other than your airflow meter...but in terms of performance wise i dont think it does anything to increase the power of ur car.
https://www.sau.com.au/forums/topic/145188-hks-eids/#findComment-2712637
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
