User:DR1FT3R
Car: R33 GTST 2door coupe series 1
Front Seats:no
Rear Seats:yes - Colour: Black, with red double stitching.
Wrinkle Front:no
Wrinkle Back:no
Logo Embossing Front:no
Logo Embossing Back:no
Handbrake Boots:no
Gear Stick Boots:no
Door Trims:no
Postage or Pickup:postage
Money Required: $150
Cheers,
Joe
Edited by dr1ft3r
  • Replies 562
Posted Images
Hi Jetdat,
Have you got anymore pics of GTR32? I really want to get a package, but I am not sure what combination is good, so more pics will be good.
Or can you give me the address of Ultimate Auto Trim? So I can go down and have a look.
cheers,
Could we still get the same deal with 12 order ? Jetdat, could you try and talk to united with that ? You can tell them that there were 20 orders previously and with this other 12 I can't see why they can't give us the same offer.
yeah man i think thats a fair call, lets get this thing going
These are the confirmations i got so far from ultimate.
>1) 08/12/2006 NETBANK TFR
> theevilworld civ06
> $630.00
>2) 01/12/2006 NETBANK TFR
> theevilworld r33gt
> $630.00
>3) 01/12/2006 NETBANK TFR
> anDru Leatherette
> $630.00
>4) 01/12/2006 BENDIGO BANK
> OL_MATE R33 S2GTST
> $530.00
>5) 30/11/2006 NETBANK TFR
> uLa32 GTR32
> $600.00
I'm about to place my order, but would like to know:
(1) Where are the seat covers made?
(2) How long should I realistically allow before I receive the order? 4 weeks? 6 weeks?
Ta
its been like 6 weeks already lol......when does the actual 4 weeks start countin. jetdat man lets get this moving if u feel like the others are wasting our time
not sure where the covers are made...
Are they made by Ultimate Auto Trim in Dandenong, Vic?
The reason i ask, is if they are made overseas i am reluctant to buy them in case something goes wrong - but if they are Aust made, i will get a set.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
