I so want in..
Before Im in Im Thinking either of these two setups..
R34 GTT Coupe 1998.. Black .. help me out here..
Black seats, Red stitching with red middle bits or ..
Black seats, Black stitching with cream/tan middle bits?
I like red but im afraid that if I get it on the interior panels such as the shifter and hand brake its going to be really bright .. Anyone got a pic of it?
  • Replies 562
Posted Images
hi, i really would like to place an order but don't no the colour codes for the leather. have looked for about an hour and still cant find any thing that can tell me what colour has what colour code.
can some one tell me what colour = code and which ones are wrinkle and non wrinkle?
moo1 = black...
m002 = ...
m003 = blue
m004 = dark grey?
and so on...
any help would be much appreciated.
thanks, loren
same here I need red door trims hand breaks and gearshift boots and the middle glove bcx cover for GTT ...same red tone as bride seats..dunno colour code
I so want in..
I'm in the same boat mate. I'm thinking two tone black with red double stitching.
A dark black outside with lighter black inside. I was thinking about a copy of the OEM seats but I saw some black leather GTR seats and they were HOT!
PACKAGE DEAL!
User: DECIM8
Car: SKYLINE R34 GTT COUPE 1998 - JUST WANT OEM STYLE
Front & Back Seats: BLACK - M001 (MAIN COLOUR [outside]), RED - M002 (SECONDARY COLOUR [inside])
PLEASE LEAVE HEADRESTS AS MAIN COLOUR M001
DOUBLE STITCHING IN EVERYTHING IN RED - m002
Wrinkle Front & Back: NO!!
Embossing Front & Back: Possable to get the skyline "S" embossed? in all seats
Door Trim, Centre Console, Handbrake Cover & Parcel Shelf, Gear Boot in: M002
Postage: Yes - NSW
DO NOT WANT: DO NOT WANT HEADRESTS IN m002 ONLY IN M001 - Rest of seat per normal
Thank you! Please let me know!
Edited by DECIM8
The group-buy administrator should set a firm deadline for payment, and a closing date for this group buy, and that way all 20 people will know when payment MUST be transferred, or they miss out. This will get things moving fast...
What if the call went out for payment by the due date or your out. Then see how many people there are, you should be able to negotiate with the supplier to see if they will honour the offer with slightly less orders.
The alternative is that we sit here doing nothing for another month, and then even after the order is put through I believe it is not a short process to have the covers made.
when fitting these seat covers, can you ever remove them . by the looks of these pics it seems that u gotta put holes in ur seat to push the ties through to hold it in place, or is it all just done from underneath .
also any word if he has purple ?
i think i speak for everyone jedat when i say can we have a list of ppl who have paid and a list of ppl who havnt......so we can see how many more ppl we need and which one of those are holding us up
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
