I so want in..
Before Im in Im Thinking either of these two setups..
R34 GTT Coupe 1998.. Black .. help me out here..
Black seats, Red stitching with red middle bits or ..
Black seats, Black stitching with cream/tan middle bits?
I like red but im afraid that if I get it on the interior panels such as the shifter and hand brake its going to be really bright .. Anyone got a pic of it?
  • Replies 562
Posted Images
hi, i really would like to place an order but don't no the colour codes for the leather. have looked for about an hour and still cant find any thing that can tell me what colour has what colour code.
can some one tell me what colour = code and which ones are wrinkle and non wrinkle?
moo1 = black...
m002 = ...
m003 = blue
m004 = dark grey?
and so on...
any help would be much appreciated.
thanks, loren
same here I need red door trims hand breaks and gearshift boots and the middle glove bcx cover for GTT ...same red tone as bride seats..dunno colour code
I so want in..
I'm in the same boat mate. I'm thinking two tone black with red double stitching.
A dark black outside with lighter black inside. I was thinking about a copy of the OEM seats but I saw some black leather GTR seats and they were HOT!
PACKAGE DEAL!
User: DECIM8
Car: SKYLINE R34 GTT COUPE 1998 - JUST WANT OEM STYLE
Front & Back Seats: BLACK - M001 (MAIN COLOUR [outside]), RED - M002 (SECONDARY COLOUR [inside])
PLEASE LEAVE HEADRESTS AS MAIN COLOUR M001
DOUBLE STITCHING IN EVERYTHING IN RED - m002
Wrinkle Front & Back: NO!!
Embossing Front & Back: Possable to get the skyline "S" embossed? in all seats
Door Trim, Centre Console, Handbrake Cover & Parcel Shelf, Gear Boot in: M002
Postage: Yes - NSW
DO NOT WANT: DO NOT WANT HEADRESTS IN m002 ONLY IN M001 - Rest of seat per normal
Thank you! Please let me know!
Edited by DECIM8
The group-buy administrator should set a firm deadline for payment, and a closing date for this group buy, and that way all 20 people will know when payment MUST be transferred, or they miss out. This will get things moving fast...
What if the call went out for payment by the due date or your out. Then see how many people there are, you should be able to negotiate with the supplier to see if they will honour the offer with slightly less orders.
The alternative is that we sit here doing nothing for another month, and then even after the order is put through I believe it is not a short process to have the covers made.
when fitting these seat covers, can you ever remove them . by the looks of these pics it seems that u gotta put holes in ur seat to push the ties through to hold it in place, or is it all just done from underneath .
also any word if he has purple ?
i think i speak for everyone jedat when i say can we have a list of ppl who have paid and a list of ppl who havnt......so we can see how many more ppl we need and which one of those are holding us up
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
