TCS = Traction Control
It's the button just above your left knee when sitting in the drivers seat.
Putting it simply; TCS is a safety system that detects when the front wheels are not spinning at the same speed as the rear wheels (in such instance it cuts the fuel/ignition making you lose power/momentum)
Turning this off enables you to drive a little differently without the car cutting out on you (e.g. burnouts, drifting, violent gear shifting...)
• Awesome for the track, no need to remember to press 'that' button
• Mismatched rims sizes (people who put R34 GTR rims on and find the TCS triggers)
• Upgraded valve bodies, hassle free driving without TCS kicking in every gearshift
• Manuals, chirp gears without losing power between shifts and boost dropping off
Now available on e-bay, tell you friends search for 'R34 Skyline TCS'
I'll discount the price for any friends of SAU members, they pay the same as you guys and not the advertised $35.
while leaving the throttle wide open and actually leaning out the engine.. bit like a rev limiter.
Kind of, it actually drops fuel from 3 cylinders as well as closing the second throttle, turns the car into a 3 cylinder for a second or so.
I got mine on Friday. Simple and quickly installed.
Works a treat. Start the car and BAM! TCS is off. No more fiddling for the switch as you approach interesting corners bends or taking off at the lights. I can finally sleep better knowing that the car isnt going to want to go limp on impulse.
:laugh:
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
