hey all i have a ceffy thats rb26 powered and i want to do a single turbo conversion with a t04z. i have the turbo and i want to get a hight mount manafold but cant really find anything,
anyone care to help me out?
also was wondering if anyone would know if i would have clearence problems cuz i dont think that there is as much room in between the motor and the bonnet as there is in a r32.
um help plz
ta ben
https://www.sau.com.au/forums/topic/146130-to4z-rb26-in-a-ceffy/
wtf is a git? i dont understand this language...
still he should be fine i have lots of pics of my turbo which show how high the turbo sits, plus its also higher due to the 3L block sitting an inch higher, and my custom bonnet has less room than the stock ones due to the design and vents etc...
im sure kyle could make up a custom high mount for rb26
ben...
yeah i got one of those shit products, only making 416 kw from it so it must be shit, with rb26 t04z.
the turbo sits really close to the rocker cover, had to modify the wastegate flange as it was facing the wrong way but.
it will fit. as they came with rb's anyway. a generic highmount will fit.
the x-force one is pretty good. it sits the turbo further back so theres more room for intake stuffs and clearance of the power steering resovior.
dump pipe is abit of a chalenge. but not that hard.
hahahahah i got the same manifold aswell. still hasnt craked and doesnt look like it is going to any time soon lol.
hmm looks like im going to have to turn the boost up.
oh. ps.. when you got yours deliverd did it say "sample diesel pipes" on the invoice to avoid tax lol.
nah nothing like that, are you running the same gear from your dr30? what power are you getting with the manifold and t04z,
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
