im on a budget of about 2k ive just thown a t04 turbo aftermarket manifold and a 38mm wastegate on my rb20 i also have a 600x300x80mm font mount on the car im a drifter i was woundering wot is the best way to go next should i get an aftermarket computer or will the sstandard 1 be fine should i get a bigger fuel pump or injectors
Edited by drftnfrysi
https://www.sau.com.au/forums/topic/146138-small-budget/
i'd say with that turbo you'll need injectors and fuel pump to be able to run any real amount of boost. i also assume you have a hiflowing exhaust system?
therefore you will need some form of aftermarket management and a tune. whether it is as crude as a SAFC through to a remap or a full aftermarket system (depending on your budget).
you say you are a drifter. more power helps but a clutch, agood lsd and suspension setup (as extreme as you want to go) will make it easier to drift and give you greater control
obviously it all depends on your budget. just keep your eye out on here for bargains on the parts you need
https://www.sau.com.au/forums/topic/146138-small-budget/#findComment-2754644
suspension you'll need for sure and tyres...lots of tyres!
even if you do get the pump and injectors the car will run like shit it want be able to control the injectors i dont think get a emange or something there cheap or dr drift re-map!
https://www.sau.com.au/forums/topic/146138-small-budget/#findComment-2754762
pod filter and box + cai or high flowing panel filter
3in exhaust, high flow cat
fmic and piping
you already have turbo so you will need
fuel pump, injectors, ecu/tune
boost control method... ebc or otherwise
z32 afm... maybe
clutch
spend money on handling/braking to make it managable (and more fun imo) to drive unless you want to drag (:thumbsdown)
mentioned above is probably more than two grand. the fact that you have chosen a large turbo means you'll require the extra fuel system items to make used of the turbo.
only tip is to do what you can yourself to assist the budget and yer keep an eye out for deals on the forums
https://www.sau.com.au/forums/topic/146138-small-budget/#findComment-2755212
  • 3 weeks later...
Stole the words right out of my mouth :dry:
More Power = MORE AIR + MORE FUEL
If one of these is missing in the equation = DETONATION
Id also use an oil cooler and surge tank to be safe...that is of course
you want to drift safely... :O
Edited by Nabil
https://www.sau.com.au/forums/topic/146138-small-budget/#findComment-2796829
to start with i already run coilovers and a 550hp heavy duty cluch i have a 3inch exaust turbo back got a pod and a massive afm and already got a boost controller
You have a stock AFM
as, if you have a stock ECU, then you wont be running a "Massive" AFM.
https://www.sau.com.au/forums/topic/146138-small-budget/#findComment-2796854
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
