G'day guys.
These are from Import Car Parts Plus in the USA.
GB: START 06/12/06 ENDS 24/12/06
What i found was a easy to use Electronic Boost Controller, that im going to order. Price is Excellent
Here's all the info on them - make sure you read all of this cause it'll probably answer all your questions.
PIT BCU Boost Controllers -
The all new BCU+ (boost controller unit) is the first boost controller to feature multiple stages of boost, a built-in turbo timer, boost guage, voltmeter, and two 12 Volt outputs. P.I.T. uses the latest technology to give the user multiple ways of controlling and monitoring boost levels. With High and Low stages of boost and adjustable gain, you can tune the boost to switch depending on track or road conditions. The BCU+ also incorporates an Automatic and Manual Turbo Timer to let your engine cool down after a run. By using the electrical Outputs you can use the BCU+ to control any 12V DC source, like a nitrous kit and/or intercooler spray. Know exactly what's going on with your engine by using the Last Boost and Voltmeter settings on the easy to read LCD screen.
To keep the price down, I need to order 10 units.
How to get onto this great deal"
You can do direct deposit into my account then I'll express post them to you after they arrive. Both ways are fully tracked so they won't go missing.
Express post cost an extra $15 nation wide.
Cost Price of the PIT EBC is $310 + $15 Freight
This gb will end in about a month or before if we can get the numbers.
Ordering To order a EBC, just put a post up here or you can PM or send me an email at [email protected] with your details.
Feel free to ask me any questions.
Also this is a price break i was given if more than 10 pairs are ordered.
10 - 15 pairs $295
15 - 20 pairs $285
20+ $275
So who wants to start the list.
LINK ON PRODUCT : also note there pricing is in US dollars
http://www.sportcompactonly.com/performanc...x?c=160&b=9
http://www.performance-trends.com/boost_controllers.htm
1) R33KID *IN
https://www.sau.com.au/forums/topic/146227-pit-electronic-boost-controller/
these look pritty good, and all in one. damn.. oi i might be in on this, just going to read up a bit more on them.. small soliniod. i wonder how accurate the readings are on the screen.. any one used one of these before, awesome price for something like this as well!
Edited by seriesII
that solenoid is good for 25psi
sweet, thanx for that. would you be able to buy a upgraded solenoid from them if i needed to go above 25psi?, that you have seen?
Edited by seriesII
  • 1 year later...
Hi guys, I have one of these EBC's and I'm struggling to get it to hold boost.
I wonder if it is a problem with the product or if the START boost & GAIN settings might have something to do with it?
I've tried ajusting the values for each, but still no luck.
If anyone has managed to tune one of these controllers effectively, your setting details would be appreciated!!
P.S. I've installed it on an R34 GT-T (completely standard).
Cheers.
Guest
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
