G'day all,
I just wanted to know what everyone thinks about the reliability of Pivot's speedmeter. I had one installed recently and on my second attempt on the M4, my 0-100 figure was 6.00 sec. I was pleased with this because I had the silencer on my muffler fitted in.
The times varied from between 6 sec and 6.3.:burnout:
https://www.sau.com.au/forums/topic/14631-0-100/
well standard is 6.2 for 33 with approx 140rwkw. Id say add exhaust and filter and boost and youd be pushing 160rwkw, and mid 5seconds to 100? Go a FMIC and some sort of management for 190+rwkw, and id say low 5seconds to high 4 seconds 0-100.
does this sound right?
Guilt toy, 4.77 is pretty quick, you must have 200+kw at the wheels? The only thing is, how do you get the traction to pull a 4.77 0-100? what tyres you got, and how did you launch?
https://www.sau.com.au/forums/topic/14631-0-100/#findComment-296975
yeah dude, i doubt 3.4 sec as well... i would say thats impossible on street tyres!! i dont think any RWD street car will be able to crack the low 4 seconds, apart from these "street" cars in japan running Nittos and 10sec qtrs!
I remember i test done with propper equipment on Kingsley Heads GTR 32, big single conversion, and i think he was only just in the high 3sec to 100 bracket. BIG power and RWD on street=inability to do exceptional 0-100's!! The power becomes a problem rathere than an aid in low gears.
https://www.sau.com.au/forums/topic/14631-0-100/#findComment-297178
250rwkw is a heap of power, and if you could get it down you'd probably do 3.4secs! But no way espec with the shit 235's you mention!
when i went from 160 to 200kw i could no longer just plant it in 1st due to traction breaking, wheras before i could let 1st wind right out.
https://www.sau.com.au/forums/topic/14631-0-100/#findComment-297188
dumb question but how does it measure the distance ?
If you sat their and ripped a burnout (tyres spinning faster than what your car could move) it would give you a 'really' quick 0-100m time wouldnt it ?
/end dum question.
https://www.sau.com.au/forums/topic/14631-0-100/#findComment-297247
Originally posted by toby19
pivot speedmeter measures 0-100 kph, 0-200 kph, 0-300 kph and 0-400 metres. To make it more clear, an olympic runner does about 9-10 sec for the 100 m sprint. A 6 sec skyline (0-100m) wouldn't be faster than a human by only 3-4 sec to 100 m would it.
LOL - I'm pretty sure they are talking about 0-100 k/ph, not 0-100m :)
J
https://www.sau.com.au/forums/topic/14631-0-100/#findComment-297616
Jay,
Your posy doesn't make sense. Toby is the one started this thread which is about the reading he took from his pivot speedmeter.
Toby,
One way to find out whether you are in fact measuring 0-100kmh is to set the meter and go for a run sitting at 60kmh. You can do this as you are cruising and don't have to do it from stand still.If it beeps and gives you a reading it is clear that the reading is for 0-100m not 0-100kmh. You can try the same for 0-200, 0-300 and 0-400. I am sure you will find that all the readings are for distance not for speed.
https://www.sau.com.au/forums/topic/14631-0-100/#findComment-297640
A cheetah would be faster than our beloved skylines over a sprint of 100meters. Basically having to move a mass of 1.5 ton and not being able to put all the power to the ground from stand still (read traction) hass all to do with it.
Obviously as the distance is increased there is no comparison.
https://www.sau.com.au/forums/topic/14631-0-100/#findComment-297661
With 180rwkw (about 2 years ago), I clocked off about 5.2 secs with a g-tech... 206rwkw and I managed a 4.9...
Much faster than that and you're pushing shit uphill with only two wheels driving, as you can only put down so much power in first and second...
Try a 100-200 time estimate if you want an indication of a cars power :)
matt
https://www.sau.com.au/forums/topic/14631-0-100/#findComment-297994
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
